Do i need a 255 lph pump?
Old 07-22-2008, 11:23 PM
foreverzero's Avatar
Default Do i need a 255 lph pump?
I have an 02 with headers, ory, ftra, p&p tb, cutout, lid, smooth bellow, and a tune. When we were on the road tunning it the computer said we kept overloading the injectors at 99%. Today switched out the original fuel filter on the car (75596 miles) and i could hardly blow through it. Since then I have not checked the car on the laptop to see if that was the problem. I dont know if this would overload the injectors. Could somebody help me shed light on when i need to add a pump? Also I made 351rwhp without the cutout, ftra, and tune, hope this helps. Thanks
Old 07-22-2008, 11:56 PM
95 Z28's Avatar
At your power level, you should have a long ways to go before you need to upgrade that pump.
Old 07-23-2008, 12:03 AM
Thanks that is exactly what I needed to know. Someone said I needed it, but I didnt think so
Old 07-23-2008, 08:05 AM
69LT1Bird's Avatar
The restricted filter would cause the computer to tell the injectors to work harder because the PCM would be seeing a lean signal and it is trying to compensate.
Old 07-23-2008, 08:34 PM
yeah, we plugged it up and it said it was running fine! made 360 rwhp and 374 rwtq with headers and a safe tune. Just curious when should I update my pump?
Old 07-23-2008, 10:09 PM
Spade's Avatar
I would get a fuel pressure gauge (good idea to have one anyways) and watch you fuel when you get on it just to make sure you stay good. I would think you do not need anything right now though as far as a new pump.
