Help with injectors for 500rwhp
I have found 42# svo injectors for $330. I figure 42# should be plenty for 500 rwhp. Anyone else know of a cheaper route to go for injectors that can handle this power? TIA.
I only plan on spraying a wet shot so I will not need injectors bigger than 42#. I have heard alot of debate over the svo vs lucas/delphi 42#. They both put out close to 49# @4bar but it seems the lucas injectors are better suited low in the rev range and are better at idle than the svos. Anyone have anything else to add over which injector they would choose? Oh, and I found the lucas injectors for $277 so these are looking like the better buy.
check out my fuel and inejctor sticky.. PLEASE. ask if you don't understand it.
ALSO, FROST is right. but it does take a COMPETENT TUNER to tune 60# injectors for small applications.
see what i'm running, I'm going to be doing a cam and will get near the 500RWHP mark; and i should be fine on injectors
