98 Fuel Tank Drop??
98 Fuel Tank Drop??
How do you drop the 98 fuel tank it seems to have a soild filler neck that can not be removed! I want to drop the tank and not do the trap door method
My question is does the filler neck come out someway i don't see?
Is there a trick to drop the tank?
have you dropped the rearend as much as possible?
ie. disconnect panhard bar and shocks? you could even disconnect the LCA's. at this point the only thing holding the rear to the car would be brake lines.
you want the rear as low as possible.
telling you, i had no rear in the car and it just fell right out after i disconnected the two straps on the tank.
I am thinking you might be right. I am not on a lift and I have not removed the rear end yet but I might have too! It's very odd that our filler neck is non removable. I feel If I could make that part some how removable I would be able to remove the tank myself. Thanks for the responses though!!!!
I ended up just pulling the tank down with the filler neck stuck in there and pulled the pump out with the tank hanging there lol. but now I bent the neck and it won't sit right with the fuel fill door.
Yeah thats basically what i don't want to do, meaning bend the filler neck. When I get the tank out I am thinking of modifying the filler neck to somehow be removable
