how much effect on speedometer?
Old 07-24-2008, 09:57 AM
KC21386's Avatar
Default how much effect on speedometer?
Upgrading from 245/50/16's to 295/35/18's.
I calculated an overall height of 663.7mm for the 18's and 651.4mm for the stock 16's.
Is this the right approach? Will 6mm larger radius change anything at all?
Old 07-24-2008, 07:57 PM
Rebob5's Avatar
I found tire calculator and it say if you go from a 245/50/16 to a 295/35/18
when your speedometer reads 65 you are actually going 66.23 mph.
Here is the link...
http://www.discounttire.com/dtcs/infoTireMath.dos
Old 07-25-2008, 07:55 AM
Xsta Z 28's Avatar
Ther is a tire calculator in the sticky . . . .
