My Autodesk Inventor 3D LS1 Build Progress
Old 07-24-2008, 12:05 PM
NiteRiderWS6's Avatar
Default My Autodesk Inventor 3D LS1 Build Progress
I have been trying to make a full LS1 engine on inventor while bored in class. heres what i have so far.
Old 07-27-2008, 06:34 AM
IllusionalTA's Avatar
don't forget the heads.. w/o them.. the intake would have nowhere to sit but on the the valley tray... look's cool though...
Old 07-27-2008, 12:14 PM
SPLATT's Avatar
throw a sheetmetal intake on that bitch lol. Pretty cool man
Old 07-27-2008, 05:04 PM
Almostryan3's Avatar
Are those the custom 2.5" piston bore? jk man its a good start. Will be pretty cool once your finished.
Old 07-27-2008, 05:47 PM
'Trust''s Avatar
Looks pretty good so far man, just couple of things:
The intake rests on the heads, so yours will be to small, and those are tiny intake ports.
The crank snout is quite thicker than that, and that whole section isn't that indented into the block.
TB and cylinder bores are too small.
All in all, 100,000x better than I could ever do, nice work!
Old 07-28-2008, 04:05 PM
bricez28's Avatar
lol yea looks fun!
Old 07-28-2008, 05:51 PM
Jakson's Avatar
Looks like a 25mm intake. Looks good though. I did the same thing last year in CADD class last year using actual specs. Never got around to doing an intake though, just the block, pistons, crappy looking heads, and a cam that turned out sweet.
Old 07-28-2008, 09:08 PM
sschkade's Avatar
That's what I was thinking LOL
Anyways, nice work OP! Needs a few things and some sizing adjustments... but definitely not bad for being bored in class
Old 08-03-2008, 01:46 AM
Phantom_LS2's Avatar
It's cool to see someone else with this kind of experience. I have over 3 years of inventor experience under my belt. I always thought it'd be cool to model an engine. Even more so to create the assembly with all the proper constraints in place to make it work like a real engine.
Old 08-03-2008, 01:58 AM
J$Money's Avatar
i take it that ur an engineering major
Old 08-03-2008, 02:01 AM
94'BLKBRD's Avatar
Nice work
Old 08-06-2008, 07:05 PM
chrs1313's Avatar
not to give you **** but you can do alot better with inventor than that...especially with the intake manifold...not bad though...
try doing a full painball gun with hooper in about 4 weeks with all other 400 level engineering classes senior year...armed with only a caliper...
Old 08-07-2008, 11:55 AM
95cobraj's Avatar
Nice. I use Inventor everyday. Been designing for 9yrs, but started 3d with Inventor6 or 7. Now using Inventor2009. I built some items off my dumdumdumdumdum with this. I will dig some pics up.
Old 08-07-2008, 01:35 PM
Mexican's Avatar
I used inventor for a little while but once I used solidworks I never looked back
Old 08-07-2008, 05:45 PM
chrs1313's Avatar
hells yeah i rocked out inventor 6 too and now am using 2009 at work...
Quick Reply: My Autodesk Inventor 3D LS1 Build Progress
