where to get bump stops?
i need a set of bump stops, but the only place i can find them is on eBay and they want $85 shipped for them. i think its a little steep for rubber bump stops. i was wondering....do they make prothane bump stops or any other aftermarket ones that might be a little cheaper?
or does anyone know where i can get cheaper oem ones? im sure the stealership will want even more than $85.
The Factory left and right rear bump stops are the same.
Energy Suspension also has some bump stops that will bolt up, but first test fit them to see if you'll have to cut the lip off(or bend it out) that sticks down between the 2 mount nuts and into the indentation in the factory bump stop. then they'll bolt up with no problem.
The only other difference is it's stiffer and a 5/8" shorter, also a lot cheaper than factory GM bump stops.
The price is for a pair.
http://www.energysuspensionparts.com...sp?prod=9.9137
check SLP. A firend ordered both of us 2 each and I wanna it was around $30 for all 4. theyre take-offs. I wanna say he siad they were 3-5 bones a piece plus S&H. Dont hold me to that all I know is I gave him $20 at car club meet and he gave me 2 new bumpstops. This was this past spring.
