fast 92 intake worth it on a procharged car 402 engine. or stock ls2 alot questions
building a 402 engine with trickflow 235 heads with a cam around 230/236 116
and a F1C procharger. trying for 16-22 psi or till i cant stop belt slip
IS it worth it to spend the money for a fast92 intake?
should i keep the ls2 intake and just run that ? should i look into porting my stock intake If worth it where to send it to for porting?
Will both intakes handle 22 psi if not what will they take?
We haven't yet experimented with the new Fast 92mm intake, but it is supposed to be better in many ways over the Fast 90mm intake. I can't help but think it would give you some additional power over the LS2 intake.If you're looking for every last hp, I'd give it a shot.
We used the LS2 intake on this build with good results.
http://www.exoticperformanceplus.com...Car.php?car=29
It would be interesting to see what the new 92mm intake would do on this engine. Bob
