Cam help for ls1 67 camaro
What would be a good "tourqer" cam similar to the one PatG used with the afr 225 heads but with tfs 215's?
This engine is going into my 67 camaro and will be using ATS tri y headers with a race style merge, 3" magnaflow exhaust all the way out, and a ported fast 92/92.
Would the same cam specs work out? Say a 228/232 low-mid 600's on a 110? Or are the valve events for these heads different? I'm looking for atleast 470 rwhp with as broad a tq curve as i can get. The car weighs 2900lbs and has a 6sp and 4:10's. I don't mind running a high compression, just as long as i can still run it on 93 pump.
