Braided power steering line question
I just converted all of my power steering lines over to the high pressure braided line. To anyone that has done this....Does the ferrel go between the stainless braiding and the teflon inner tube? Just want to make sure I did this right.
That's how the Earls/Russell fittings are. The nylon tube slides onto a nipple, then the ferrel slides over that, then the fitting gets tightened. At least I think that's how it went. It's been a while since I did mine.
Supposed to be good for 2500psi
yes these are the earls fittings. I have one of the O ring fittings leaking at the steering rack. I can't figure out why. I"m gonna pull it apart tomorrow and see if maybe the oring broke.
here is the write up I went off of.
https://ls1tech.com/forums/forced-induction/367551-stainless-braided-power-steering-lines.html
Back from the dead.....
How the hell do you get these to start threading? I don't have a vice and cannot get these to start threading. I got the fitting in as far as it will go down and cannot get it to start threading. Are you supposed to remove some of the braided part? Thats the only thing I can think of.
I got the high pressure side all done, but I don't have my downpipe in to route the low pressure side. I got the straight one done, but I just have to get the new turbo and dp in so I can route this. So I guess Ill through some tape on the fittings.
Anyone know what you are supposed to seal the fittings with?
https://ls1tech.com/forums/showthread.php?t=367551
What a time saver, thanks!
