whistler mod anger!!!! ..help
ok well im trying to get the damn lens off and i cant...... and im worried about prying harder on it cuz i dont wanna break, and i keep putting it in the oven but it seems like im going no where fast.. please help ill take suggestions now
The best advise I think is to be patient and pry very slowly a little bit at a time with a screwdriver. You will see it start to lift a little bit. Once it does at that point, move down about 1" and pry there. Eventually you will make your way around the whole lens.
Also, I would try not to be too patient as mentioned above. The silicone hardens quicker than you think and as the that happens the headlight starts to chip. The best route is to just put it in the oven a little longer, lift one corner, and you can about pull the lens off by hand from there.
Correct, you don't wanna be too patient, but at the same time you don't wanna push the screwdriver though the plastic so hard that you chip it. Granted, I did mark mine up a bit w/ the screwdriver, but it's in a place that you'll never see once they are reinstalled. A higher temp might work, I went with 200* just because I read that somewhere around here.
