Corvette Performance - Z06 Compression Ratio Question?
Whiteboy572ci
07-27-2008, 10:17 PM
What makes the compression ratio change from a 10.1 on an ls1 to a 10.5 on a ls6 (both 2001, camaro vs. z06) did they simply use a smaller head gasket on the z06 or change the cc volume down to a 64cc?? I wanted to get the 215 trick flow genx street/strip heads and have a final compression ratio around 10.9-11.1. Would i have to get the heads milled down some or is there somewhere that would sell a thinner/stronger head gasket?
tmaschm
07-28-2008, 07:31 AM
Good question I have no idea.
~JOSHUA
07-28-2008, 10:42 AM
The combustion chamber is smaller on the LS6 (243 casting) compared to the LS1 (853-early, 241-late) heads...
The actual cc's come out to be (with stock head gasket) -same head gasket for both.
LS1 = 67cc's
LS6 = 65cc's
Sigforty
07-28-2008, 03:36 PM
LS1 = 67cc's
LS6 = 65cc's
He got it!!
fastvet
07-28-2008, 03:46 PM
Just remember that when you mill the heads, you are not running the same flow on the heads that you originally started with. Yes you have more compression, but the heads will flow a bit less. My advie to you is get some 5.3 liter heads and you should be close to 10.75-10.8 C/R then use a .040 or smaller gasket from thunder racing and that should put you in the range that you want to be at.
Whiteboy572ci
07-28-2008, 10:26 PM
Awesome, thats what i thought that an ls1 had 67cc, being the reason for lower compression than the ls6, kinda figured that a manufacturer wouldnt use smaller h/gs so they wouldnt have to make 2 differant h/gs for the ls1 and ls6. I was looking at doing the trick flow h/c package or one of the patriot h/c packages, now possibly a 5.3l head, the stock ls6 lim will fit to the intake runners on the 5.3l heads, right? Im shooting for 470whp-510whp range all n/a. Off the wall, when do the stock 2001 Z06 injectors duty cycle get too high ~85-90% range? I like the titanium exhaust sound and all but will an aftermarket axle back yield a great deal of gain over the stocker? >10whp?
Thanks again!
Cole Train
07-28-2008, 11:01 PM
i have Z06 heads with .051" thick Cometics. i should see what my compression is:D
Sigforty
07-29-2008, 08:01 AM
Thanks again!
When you get to around 450 rwhp the Z06 injectors will be around 105% duty cycle.
Whiteboy572ci
07-29-2008, 08:20 AM
So what size should i move up to? 42lb? I want to have ~500whp with a duty cycle at about 70%.
fastvet
07-29-2008, 08:21 AM
^^^:werd:
Just buy some 42lb injectors to get the car ready for some mild spray later on down the road!!
Whiteboy572ci
07-29-2008, 09:16 AM
Wheres the best palce to get them value wise and new not refurbs? It would be awesome if they just plugged in too, i had to splice the connectors in on my turbo'd grand am.
fastvet
07-29-2008, 10:13 AM
PM sent
Sigforty
07-29-2008, 10:52 AM
I would suggest 42's especially if you plan later upgrades. The SVO 30's are good, but if you want to add more later or do a dry shot you will want the 42's.
