With all these cam setups i see (newb question on advancing)
7 Second Club
Re: With all these cam setups i see (newb question on advancing)
Generally the cams are advanced from the grinder. If I remember correctly advancing will create more cylinder pressure by changing the intake closing point. Going to a larger cam will lower your effective compression ratio but by advancing it you will gain some back.
Phillip
Phillip
