got 2 ?s
got 2 ?s
got 94 ta 150000miles mods are lts,cai,elbow,pulleys, duel 1 chamber dumps,3.73,tb bypass,foil8.5mm wires,255 pump,ngk plugs,lt4 knock mod.and 100shot wet kit. Before nos kit the car went 8.48@83.2 1.95 60ft. Anyway the ? is i just picked up a set of 1.6rr. Do i need to change my spring before i put them on. Also i going to dyno the car wat do u thank it will put down on spray.
If it were me and I was running the stock cam and 1.6 rockers I would invest in a set of lt4 valve springs that can be had for very cheap and that way you will have more room in terms of lift. Of course I have seen many run the stock springs with 1.6 rockers so it can be done but to reduce the risk of coil bind I would personally upgrade the springs.
