Modified Crossmember Brackets
Old 07-28-2008, 10:46 PM
transamws6_97's Avatar
Default Modified Crossmember Brackets
So I'm in the process of getting BMR's crossmember put on my car because I like their design a lot better than UMI and Spohns. Well we are taking it even further by putting beefier brackets where the crossmember mounts to the subframe connectors.
test fitting the crossmember before we cut it to size and weld it up.
our bracket is the square metal tubing
