Is the WBO2 on the LC1 the same as all the others for connectivity?
I'm curious. Ever since I got this piece, at operating temperatures in the hot heat of Jersey, the AFR ocillates and throws the tune completely off. Confirmed with both Innovate scanner and hpt scanner. So it's definitely the controller and/or sensor.
So I figure the cheapest is to replace the sensor and see if it still happens. Will a replacement WBo2 sensor just plug into the LC1?
If I find the LC1 is a paper weight, will this sensor just plug into other WBo2 Units out there like AEM?
Thanks for any direction
