How Important is CR.
Old 08-26-2003, 04:58 PM
HumpinSS's Avatar
Default How Important is CR.
Going from 10.1:1 to 11:1. How much HP gains best and worst case senerio will you net?
Old 08-26-2003, 05:43 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Default Re: How Important is CR.
It's said that every full point increase in compression is worth 3% additional HP.
Some cams work better with more compression.
Old 08-26-2003, 05:55 PM
GeorgeC's Avatar
That's a pretty good jump, and should net a decent increase in HP... An 11:1 LS1 shouldn't have any problems on pump gas, so it's a worthwhile jump.
You get to a point of diminishing returns on CR though... What I mean is that you will gain much more going from 9:1 to 10:1, than you would by going 13:1 to 14:1...
Old 08-27-2003, 02:45 PM
robertbartsch's Avatar
My heads are milled .055 and yield an approximate static compression of 11.4
I run 93 **** gas and do not have any knock, however I am running a tad rich. ...the knock verification has been performed on A-Tap..
