Need help with injectors
either 37# or 42# injectors. please read my fuel and injector sticky
https://ls1tech.com/forums/fueling-injection/293742-fuel-injector-size-calculator-fuel-pump-chart.html
that will tell you all you need to know; if you have any questions just ask me or PM me and I can get you situated
and you are ready to go.
I would honestly recommend just buying some racetronix 37# or 42# injectors. IF you want to get flow matched injectors , go for it. RCENG makes injectors also, they are just harder to fish through to fine the right #/hr rating and such; they have really great injectors
need help with injectors
i have a 98 ta with a 383 stroker and a tr224/112 degree cam.it still has stock heads and intake which will be changed this winter but for now i just want to drive it so i am having it dynotuned. i have no idea what kind of power i am puting out but i want to get injectors before the tune. any ideas on what size injectors to get would really help. i know i'll need to get it retuned again after the new heads/intake but if possible i only want to buy injectors once. i also plan on spraying it next year after i can get it to hook.
Last edited by BrokeRacing98ta; 07-29-2008 at 05:19 PM. Reason: unclear about details
https://ls1tech.com/forums/showthread.php?t=293742
Thanks
i have a 98 ta with a 383 stroker and a tr224/112 degree cam.it still has stock heads and intake which will be changed this winter but for now i just want to drive it so i am having it dynotuned. i know i'll need to get it retuned again after the new heads/intake but if possible i only want to buy injectors once. i also plan on spraying it next year after i can get it to hook.
If DRY, then I would invest in some 48# racetronix injectors, or find the equivalent at RCENG.com
if WET, then you should be fine with some 42# injectors
I read your sticky but does not mention if your running N2O or what shot. so, if I'm running 425rwhp and want to run 100 shot or 150 shot of nitrious what injectors? I also am planning to go either 40x or 383 stroker, what size injector do you reccommend to use on my 425rwhp that I can as well use on my stroker?
Thanks
Thanks
if WET, you will be fine with 42# injectors, 48# if you have future plans and plan on doing some more power; BEING that you are saying you are going to go STROKER, I would get the 48# injectors, or equivalent from RCENG.com
the 48# is actually a 55# injector at our fuel pressure and that should carry you to 650HP or higher depending on wet/dry and such
now if anyone is spraying a dry shot, i recommend going wet, lol.
otherwise invest in some 60# mototrons and get a GOOD TUNER to tune the injectors, if you cannot get a good tuner, talk to gametech up here; he has tuned them to where they do not idle rich and can probably help you.
Those 60# injectors will be good for a whole lotta HP ; and I only recommend them to people that have pretty high setups that are N/A (at 550HP +) or mid-high range FI applications (in the 700-800rwhp ballpark)
BUT with proper tuning and adjusting , 60# injectors CAN run on a basically STOCK car and NOT idle rich
I know gametech has tuned several cars with 60# injectors (or helped tune) and he knows how to get them to run right without having a FPR, just tweaking tables. Hell, and I know you have messed with them too.
what we honestly need, is ALL of the tables posted up that were changed to get a one particular persons car running on them that was close to stock or something like that, so that when people to buy the 60#ers that they ca kind of see where they need to go with it.
They should list the 48# injectors and their ratings, they make them and show their ratings and sizes.
YOU NEED TO MAKE SURE THEY ARE HIGH IMPEDANCE INJECTORS
Saturated ones:
Just clicking around and looking:
http://www.rceng.com/Saturated-Injec...440-P30C6.aspx
there are 42# injectors
http://www.rceng.com/Saturated-Injec...550-P31C6.aspx
52#
http://www.rceng.com/Saturated-Injec...650-P32C6.aspx
62#
