Need help locating some parts pls!
Finally tore down the new Lt1 car and found that the knock was a spun bearing on #8 cycl. I'm sure it can be machined but I was wondering if there is a vendor out there that sells an OE rotating assem. It's going to be a DD so I don't need anything extreme but wouldn't hurt to be a little tougher on the bottom end.
I plan on replacing or machining the crank(if I can't find a kit/assembly), new rings, bearings, etc. "Freshen up" if you will.
Any help will be appreciated!
