Biggest single nozzle shot youve ran?
Old 07-30-2008, 11:57 AM
Bucktooth's Avatar
Default Biggest single nozzle shot youve ran?
Whats the biggest single nozzle shot you guys have ran? I am talking like a shark nozzle etc...
List jet sizes if possible.
I am currently running a .067 jet so about a 175 shot.
Old 07-30-2008, 12:00 PM
FUKALS1's Avatar
i remember we ran a huuuuuge *** jet in our crx one time (b16), just to see what would happen. i'll try to find it to give you the actual size but i remember it coming out to around 200 shot hahahaha
i know it's not an ls block, just throwing that out there for stupidity sake
Old 07-30-2008, 02:44 PM
69_YENKO's Avatar
I was reading a very similar post the other day and a couple had said they had gone a much as a 250 through the NX shark nozzle. you might try a search and see what you come up with.
Im curious how big a shot a single TNT nozzle will support if any one knows...?
Old 07-30-2008, 10:04 PM
mrr23's Avatar
i've done 200 through the NX single nozzle.
Old 07-30-2008, 10:27 PM
sciff5's Avatar
I know one of the the ls1/rx7 guys was running a 250 shot for a while through a single nozzle on his stock bottom end Ls1 and it was finally ptv contact that wiped out the motor, not the nitrous. Pretty amazing
Old 07-30-2008, 10:33 PM
Mike@HSW's Avatar
i wouldnt run more then a 200 shot from a single discharge point
Old 07-31-2008, 07:46 AM
Bucktooth's Avatar
What if it were the last few passes of the summer/motor.
Old 07-31-2008, 10:10 AM
Nitro Dave's Nitrous Outlet's Avatar
The shark nozzle will flow 250 HP. The limiting factor will be the -3 hose between the solenoid and nozzle. To go over 175.00 you will need to upgrade that hose and the exit fitting on the solenoid.
NX makes a SHO nozzle that will flow 400 hp. Some classes use to restrict racers to these nozzles. Tunning in that large of a shot on a nozzle really came down to knowing your stuff. The only time I would suggest doing that is if that is all the class let you do and you knew how to read plugs.
The shark nozzle will flow fine at 200 and I have personally set many of cars up back in the day using it with great results. Our plate would obviously be a better solution but you can do it with that nozzle. I would suggest reading the plugs while tunning it in.
If you need any advice let me know.
Dave
Old 07-31-2008, 10:24 AM
Bucktooth's Avatar
Dave
I will have a a/f meter and ill pull plenty of timing. I hav ea 4an line going to the nozzle with 3an fittings.
Thanks
Old 07-31-2008, 10:26 AM
It should flow then. The airfuel meter gives you an over all reading. Reading the pugs will tell you what each cylinder is doing incase one is burning leaner than the others.
Dave
Old 08-01-2008, 10:16 AM
sciff5's Avatar
Dave
Nice, good to know the kit I got used it up to the task of spraying some serious numbers if I want to up the shot. I have a shark nozzle and iceman proflow solenoids
Quick Reply: Biggest single nozzle shot youve ran?
