stevieturbo
07-30-2008, 05:21 PM
Another long weekend, and finally a 9sec
Still not impressed, as basically the only reason its doing it, is I was using ET Streets ( 26x11.5x16" )
The car, while it does feel good, has performed better. Its just lost so much over the latter parts of the track compared to how it used to perform.
60ft..........1.55
330ft........4.21
1/8...........6.41 @ 113.83mph
1000ft.......8.23
1/4...........9.85 @ 144.75mph
Also did 2 x 9.99s runs with lower mph. Would have got some more, but the boost pipe kept blowing off the supercharger.
Still pump fuel + 70/30 meth/water
]Another long weekend, and finally a 9sec
60ft..........1.55
330ft........4.21
1000ft.......8.23
http://www.youtube.com/watch?v=XgWRCDtiTQ0
Car ran well all weekend.
At an event on Sunday at an airfield, I ran 181.9mph over a standing kilometer ( 1000m ) on road tyres ( Toyo 888's )
By comparison...best 1/4 at that event was 11.15s !!!!!!! Absolutely no traction at all, either on 888's, or MT DR's
Basic spec...
383 LS6 block
JE Pistons, Callies rods, Eagle crank, EPP cam, TFS 225cc heads, 1.7 YT Ultralights.
Carb intake + elbow, 85mm TB, custom 2" headers with dual 3" exhausts, dual 044's, DTA S80Pro ecu, Vortech V7 YSi, custom 12 rib drive, custom FMIC
T56 gearbox by Sixspeedsinc, stock gears, cryo'd, uprated shifty bits, Viper o/p shaft. Textralia triple disc
Ford 8.8" rear end, Torsen diff, MW 31sp axles, 3.55
60ft..........1.55
330ft........4.21
1000ft.......8.23
60ft..........1.55
330ft........4.21
1000ft.......8.23
Basic spec...
383 LS6 block
