General Maintenance & Repairs - Head lights flip when car is locked and unlocked
Dood001
07-31-2008, 04:56 AM
title says it all, and i don't know why its happening. as for the weird sound, it might be the light motor thats giving up because i have notice it has had problems picking up. the lights going up and down when locking and unlocking might be a wire problem but why all of a sudden? anyone had this problem before? i havent changed the alarm, its the stock one...
http://www.youtube.com/watch?v=LOVqS7_Ca9A
TA-Swede
07-31-2008, 05:58 AM
It's one of the "modes" the alarm can be configured to.
Read the manual, and it's all in there. If you've lost your manual: http://www.camarohighway.com/Manuals/
As for the sound, it's the gear in the headlight motor that's given up. There's tons of info on how to do a quick-fix for it (rotate it 180 degrees), and someone out there selling a brass replacement that fixes the problem permanently.
/James
98silvertacrbn
07-31-2008, 02:07 PM
My 98 ta did the same thing replace the gear in the headlight motor or flip it over and it will stop making the sound and going up and down when you set the alarm
udienow
07-31-2008, 02:19 PM
anything you might need to know:
http://www.bfranker.badz28.com/headlightfix/index.htm#FreeGuide
Id go with the free mod and just flip the gear 180 degrees for now, but I encourage to read the whole page.
AlexLs1
07-31-2008, 02:30 PM
I had the same problem. Flipped the gear around, it was fine for a while. Then I ended up replacing the head light motor down the road.
bjamick
07-31-2008, 03:36 PM
Yep you need to do the 180* fix on the gear. It fixed my car.
Warbird98
07-31-2008, 04:16 PM
Same here flip the gears are get brass ones. got mine from classic industries
Detoxx03
08-01-2008, 12:02 AM
Time to repair the gear
Danny2tek
08-02-2008, 07:06 PM
Read my sticky in the Firebird forum....
http://www.ls1tech.com/forums/showthread.php?t=177470
P.s... Do you mine if I use your video in my sticky?
Dood001
08-05-2008, 03:54 PM
I dont get this...
"This next part is important! You now need to, while CLOSELY watching the motor shaft, rotate the raise/lower manual knob so the motor shaft turns exactly 180 degrees (or half a revolution). Once you have completed this, reattach the headlight raise lower arm. What you have just done is made it so the actual motor gear will now be in contact with the *other* half of the plastic gear. Sure, the teeth on the plastic gear are stripped, but they are stripped on the now unused side of the gear :) "
needadvice
08-05-2008, 05:01 PM
I dont get this...
Thats right, and the good teeth are now on the USED side of the gear.
What don't you get??????? :D
Dood001
08-05-2008, 05:16 PM
ok, wait i think i got it. when i take it out from the SHAFT,i then go to the MANUAL RAISE KNOB, and turn it 180 degrees. then reconnect it back to the SHAFT?
Danny2tek
08-05-2008, 05:57 PM
thats correct now your using the unused portion
Dood001
08-05-2008, 06:36 PM
whats the point of taking it off from the SHAFT then? if ima reconnect it back...
needadvice
08-05-2008, 09:52 PM
Because it will over-crank in the direction you turn it.
Just take the shaft off and do it. This has been done 1 million times.
:chug:
Dood001
08-05-2008, 10:15 PM
lol i took all the three damn screws holding the damn motor... i thought i had to take them all off but i was doing the method of replacing the gear... idiot!
Danny2tek
08-05-2008, 10:20 PM
dont worry when you do your other headlight you'll be a pro
Dood001
08-07-2008, 02:08 PM
alright i just got done doing or i should atleast say tried doing the 180 fix and it seems like its still doing the noise... am i suppose to turn the MANUAL RAISE KNOB left or right? (i know i know, do it after you have taken it off from the SHAFT)
Dood001
03-28-2009, 03:38 PM
You guys know where the brass gears are cheaper at? i know 85 buks aint much but just wondering. SAME gear dealing with this thread went out... :mad: and my passenger light hasnt given up. W T H ! !
