A good Security/Remote Start for $1-150?
Old 07-31-2008, 08:47 AM
Dimitri-'s Avatar
Default A good Security/Remote Start for $1-150?
Ive been looking at the python 990 for a security/remote start system, but the cheapest im finding is around 240, and then installation which I dont even know how much will be.
Had a recent prob w/ the car which set me back a few hundred dollars (just a college kid :<) so I dont think I can do the python. Anyone know any decent systems in a 1-150$ price range?
Old 07-31-2008, 10:09 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
I like code alarm, have you considered installing it yourself? Most newer systems come with on-board relays and it makes installation MUCH easier for the DIYer
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 07-31-2008, 11:01 AM
Dimitri-'s Avatar
Ive heard the system is only as good as the install, and seeing as how I havent done one before, wouldnt be such a good system then haha
Old 08-01-2008, 02:12 PM
djfargot's Avatar
i would NOT try to learn how to install an alarm/remote start on the fly. it isnt that the install is terrible (its not easy by any means) but there are so many things that you have to understand and know how to program to get everything the way you would like it to be. i wouldnt take it to a retail installer either (circuit city/best buy).
if you know someone that is familiar with it then i would say go for it. it will take you some time though!
Old 08-01-2008, 04:23 PM
samson_420's Avatar
I have had a good experience with the Prestige 996a. There are a few model numbers almost like it but I don't remember them right off hand.
It should cost you about 150-175 to build a real good low budget two way LCD security system.
Old 08-01-2008, 08:57 PM
Dimitri-'s Avatar
Anybody have input on the Clifford Matrix RSX 3.5? Ive found that I just dont think Ill get a quality security/start for less than 200 :X
I found it on here, has all the specs http://www.hookedontronics.com/show_...2&brandtype=83. I think I may be swaying between that or just spending the 220 on the python 990
Old 08-02-2008, 02:11 PM
Dimitri-'s Avatar
Woww, I called this place EZConcepts on LI and they said 475 for installation.... lol.. Looks like I am not getting a system any time soon
Old 08-04-2008, 10:31 PM
chepito's Avatar
Default x
Try Circuit City. They should not charge you more than $200 for install. If you can, spring for the dual motion sensor too. I don't think you need a key bypass.
Old 08-05-2008, 10:18 PM
bmnicolosi's Avatar
i work for circuit city(install manager for past 5 years), and i would charge 160 base labor, plus 80 for the lock system in our cars, plus 85 for the r/s bypass. So, circuit city would be about 325. And i have the 990 in my z28, my avalanche, my brother's g20, and my fiancee's jag. Great alarm.
Old 08-05-2008, 11:09 PM
SprayAllDay's Avatar
if your looking to save a little cash check the python 872 or the 871 is its predecessor still 2way shorter range no screen and no if you've never done an alarm/rs before an f-body is definatley not the car to try it out on you dont need a r/s bypass but you do need to wire in a relay with resistors to bypass the vats(chipped key) you'll also need 2 relays for the door locks and a third if you want trunk pop +1 for the motion sensor especially if you have a T-Top car I would also add a mini piezo siren under the dash I recently installed a viper 791 (similar to 990) in a friends y2k Z28 the piezo is ear bleeding! works great, good luck pm me if you have any questions I still have all the paperwork for f-bodies
Old 08-06-2008, 08:40 AM
Dimitri-'s Avatar
I found a Viper 5900 for 195$ that I may get, and a place that would install for $200. So I think it might be the next mod.
Anyone know if the 5900 is able to pop the trunk too? I cant find it on the product details
Old 08-06-2008, 11:44 AM
bmnicolosi's Avatar
Yes it can pop the trunk. And you do need a bypass, it is a relay and resistor matching the resistor on your key.
