k-member bolts
Old 07-31-2008, 02:00 PM
cjg454ss's Avatar
Default k-member bolts
i got the bmr turbo kmember, what size are the bolts that connect the lower control arms to the kmember. i can seem to get the right size. thanks
Old 07-31-2008, 02:10 PM
UMI Performance's Avatar
The are 14mm x 100mm and 14mm x 110mm
Hope that helps!
Ryan
Old 08-01-2008, 08:00 AM
cjg454ss's Avatar
what size wrench do i need? sorry for the confusion, i have the bolts.
Old 08-01-2008, 11:06 AM
LS1Tech Sponsor
MADMAN's Avatar
I normally use the wrench that fits the head of the bolt. If that doesnt work a "amerametric" will work also.
__________________
www.madmanandcoracing.com
225-343-9029
Old 08-01-2008, 11:09 AM
edcmat-l1's Avatar
LOL, would that be the same as an all/16ths? AKA, thumb wrench?
Old 08-01-2008, 11:13 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
I believe that is what he is referring to. LOL
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 08-01-2008, 01:05 PM
LSX Mechanic
Damian's Avatar
Put a 1/4in socket/ratchet on there and go to town. If you can't get enough TQ, use a break bar on the 1/4 ratchet.
Old 08-01-2008, 01:25 PM
Moderator
thechef's Avatar
just use ViseGrips, they work perfect
Old 08-02-2008, 07:46 PM
2000_SS's Avatar
you don't know what size wrench you need? you have the bolts....and their specs now....and you don't know what size wrench you need...?
i hope there are some extenuating circumstances here i'm not aware of, or maybe you have some type of short-term memory loss....i'm not usually a dick, but if you can't pull a drawer open and pick a wrench that looks close, try it out, and use it or get the right one if it doesn't fit....you probably should not be anywhere near your car and let someone else work on it...
if i'm out of line on this one...someone clue me in to what's going on here...
Old 08-02-2008, 08:40 PM
cjg454ss's Avatar
no i was at work and didnt have the bolts with me, i was looking to pick up the wrench on the way home and didnt have the bolts to check. i appreciate the info, i just took them down today and got the size
IT WAS 13/16ths
Old 08-02-2008, 09:29 PM
2000_SS's Avatar
ah...ok...
Quick Reply: k-member bolts
