Drag swap suggestions....
Old 07-31-2008, 02:01 PM
djsanchez2's Avatar
Default Drag swap suggestions....
Of fellas, since my SS has developed a case of the old rod knock, I have started collecting parts and motors. I have acquired 2 complete LS1's and a Ls1 block, a TH400, 4L60e and T-56. Overkill? Nah just REALLY REALLY good deals.
Anyways since i have a couple extra motors i was thinking i can attach one to my built TH400 and toss it in a car. Thing is what?
I need something that has a strong rearend, yet is lighter than a camaro. I was thinking 1977 Caprice 800lbs lighter, factory 8.5 10bolt rear , but i'm still not completely sure.
So go ahead and shot fellas.......
Old 07-31-2008, 02:09 PM
subtlez28's Avatar
77 caprice is 800 lbs lighter?
Suggestions:
-gutted 2nd gen (factory 8.5s)
-S-10 w/ 8.5
Old 07-31-2008, 02:16 PM
97'-lt1's Avatar
There are alot of us now but a fox swap is good. I should be finishing mine up in a few weeks hopefully..6.0/TH400 swap..Should be in the range of 2500-2800lbs when complete..
Old 07-31-2008, 02:17 PM
fast's Avatar
anything UNcommon ... caprice fits
good luck with it and enjoy!
Old 07-31-2008, 02:43 PM
djsanchez2's Avatar
^^^ That's exactly what i was looking for.
And yes the lil boxy caprice cop cars were light lil SOB's.
Old 08-06-2008, 02:07 PM
KC Henry's Avatar
I have had good results with my 1978 Caprice with a stock LS1.
I say do it... you will like the results.
Old 08-07-2008, 10:44 AM
LS1TECH Sponsor
Carshopinc.com's Avatar
For a light weight application I would suggest three cars that come to mind...
First car would be a first gen s-10, in stock form it has a 10 bolt but I have beaten the hell out of my ten bolts with auto's and don't think thats a major issue..... My 87 with a 355 sbc, t56 trans and a cut through with four Phoenix gold x max tens and a few alpine amps scaled 3020 pounds.... I am sure without the extra creature comfort we could have been in the 2800 pound range for sure.... add a ls to the mix and look out!
Next is the rx7, fd's are cool but cost alot so this leaves you with the fc and fb (). All three cars are light and fun to drive (wear a mask in the fb) but the fc and fd had independent rears which do work but are not the most ideal for drag racing..... fb's if I remember correctly have a straight axle and are the lightest of the three.....
The third would be a mustang...... Swap parts are now readily available they already have a 8.8 rear that can take a beating and can scale around 2800
Old 08-07-2008, 12:23 PM
nalc's Avatar
Is the 77 Caprice really that light? I had an 89 B-body, which is the same generation, and it came in well over 4,000 lbs. Granted, mine was a wagon, but are the sedans really that much lighter? Or did they just add a bunch of crap to it during the eighties that made it heavier?
Old 08-07-2008, 01:53 PM
ryanvv355's Avatar
G-body Malibu gets my vote, you can track down G-body 8.5's.
Old 08-07-2008, 03:36 PM
Quaman's Avatar
^^^ Gbody Bu's are just sick lil cars,budy had two identical lite blue ones.One a 2 door the other a 4door,2door smackd the guardrail around the 330..so the go fast goodies go in the 4 door,and it actually went QUICKER!60's picked up from consistantly in the 1.71/1.72 range to 1.68's on the dot.
Also AMC Javelin/AMX's not the early 70's (71,72) as there just dog ugly,but 70 and below are rather good looking cars,engine placement/turbo mounts should be identical to most older mustangs/fox bodys.
Regal Beagals and cutlasses also have that good stock suspension we love, and the after market just keeps growing for them aswell.
Old 08-07-2008, 05:13 PM
ten5nova's Avatar
How about a 75-79 Nova?
Old 08-07-2008, 07:42 PM
KC Henry's Avatar
Mine weighed 3,660 with gas, spare tire, jack and a bucket of cleaning supplies (3,860 with me in it).
Cloth seats, A/C disconnected, manual windows, manual locks, manual seats.
So it is lighter then some fully loaded F-bodies.
Old 08-07-2008, 08:02 PM
mrnorm_hemicide's Avatar
RX7 for sure. The cars are light as a feather from the factory, and not only are they fast as ***** with an ls swap, but they handle good as well lol!
Old 08-25-2008, 11:58 PM
djsanchez2's Avatar
I have been considering a FC RX-7 they are supposed to weigh 2700lbs after the swap with a T-56. I will be using a TH400, so i don't if that will add or drop a lil weight.
Old 08-26-2008, 12:06 AM
bczee's Avatar
My 71 Nova weights in around 3000-3200
Quick Reply: Drag swap suggestions....
