Manual Transmission - Speedway T-56 LS1 Hydraulic Clutch Kit
HavATampa
07-31-2008, 09:19 PM
Has anyone tired reverse engineering this kit that Speedway Motors sells to replace the crappy hydraulics in our cars? It's meant for non F-Body projects that are using the T56 transmission and it's release bearing with quick release fittings. They sell a seperate line kit with several sizes of the braided hose, and fittings to fit the hose on a 7/8" bore Wildwood replacement master cylinder.
http://www.speedwaymotors.com/p/9086,,_T56andLS1-Clutch-Lines.html
http://www.speedwaymotors.com/p/1133,,_Universal-Master-Cylinders.html
Jonathan@Tick
07-31-2008, 09:46 PM
The master bolts into the firewall on an f-body at a very odd angle. The flange that bolts it in is also located in the middle of the body, not on the end like the wilwood cylinder.
