Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C5 Blinker blinker faster than normal??????????
Old 08-01-2008, 06:51 AM
a.white86's Avatar
Default C5 Blinker blinker faster than normal??????????
I have replaced the left blinker BULB in a C5 and it still blinks very fast. RIGHT BLINKER blinks as normal speed. Both are new bulbs. ANY IDEAS!!?????? PLEASE HELP ASAP!
Old 08-01-2008, 08:07 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Check the bulbs on both the front and rear on the right side. A bulb out in either location will cause that side to blink faster. Check both rears one also If all the bulbs are good, then it is the flasher unit. A little more expensive, but not too bad and easily changeable.
Keith
Old 08-03-2008, 09:34 AM
V-seriesTech's Avatar
buld/switch(turnsignal)/hazard switch(most likely)
Old 08-03-2008, 10:30 AM
Sawzall and Welder Mod
Whistler's Avatar
Perhaps the fluid is low..
Old 08-03-2008, 03:58 PM
lol....
Old 08-03-2008, 04:59 PM
99FRCTorchRed's Avatar
Maybe a turbo blinker........
Old 08-03-2008, 11:46 PM
Cole Train's Avatar
yeah check ALL the bulbs. It's that or the multifunction switch is bad
Old 08-04-2008, 07:50 AM
ls1290's Avatar
Or turning signal additive was not used with it. Turning additive increases responsiveness 23.8% and brightness 2 times. Do not change your blinker fluid without adding turning additive. Just not worth not using it IMO.
Keith
Old 08-04-2008, 05:48 PM
Whistler's Avatar
And only use the GM turn signal additive. The parts store junk will cause radio interference and make your GPS give you bad directions.
Old 08-05-2008, 07:33 AM
allngn_c5's Avatar
Definately some sig worth comments in this thread. Had me rolling.
Gotta love the smell of blinker fluid when it comes up to operating temperature. Reminds me of Napalm.
Old 08-05-2008, 07:53 AM
ls1290's Avatar
Plus your dealer will void your power train warranty if they find out you have been using non GM turn signal additive. That is just a chance I am not willing to take, so the few extra dollars is totally worth. Most dealers do have a display that shows how turn signal fluid preforms by its self and with GM turn signal additive. Just ask them and they will be more than happy to show you it.
Keith
Quick Reply: C5 Blinker blinker faster than normal??????????
