My car say's no go help plz
Old 08-01-2008, 06:33 PM
Kmaroman's Avatar
Default My car say's no go help plz
my car won't start it doesn't even make an attempt to start it just keep's cranking and nothing happen's. I hear my pump come on but still nothing. I just fixed my heater hose that was on top of the pump from the pump to the heater core. It leaked down but when idrove home it ran fine when i went outside to start it up 3hrs 30mins later nothing
Old 08-02-2008, 01:07 AM
dre2013's Avatar
when you say pump im assuming water pump...which means you probably got your opti wet. let it sit for a day or so and hopefully itll dry out.. mine had the same prob and ran fine after sitting for 3 days in the sun
Old 08-02-2008, 09:41 AM
bricez28's Avatar
x2 my car had the problem first the opti timing was off cause someone forced it together wrong. and then it got wet.
