Question about 90mm intake manifold installation
First of all, Im still running the LS6 intake, and I will be until I do my head/cam swap. I remember reading something about there being a problem with the 90mm intake installation. I dont remember exactly what the problem was. Does the intake not sit flush on the heads or something? If Im wrong, then Id just like to know what is required for the install. Ive done many head/cam swaps so Im very familiar with how the intake comes on and off. I just wanted to know if the 90mm intakes need some kind of special attention. Thanks
Be sure to change the valley bolts as mentioned. If not you will crack the bottom of your intake. Also, the crossover tube in the front of the heads will need to be gently tapped downward some as the neck of the intake will hit it if not.
i love my fast . done several intake installs and the fast was not much different .
as mentioned the sensor on the very back of the intake (map sensor) is a bit small for the hole fast provides . rtv silicaon gasket maker can take care of that . then the bolts for the valley cover an be purchased if they do not come with the intake .
as far as it mounting up good i have never had a problem . also you can port it out for some good gains .
