Where are you running your N2O main line???
I am slowly finding time for my wet nitrous kit install and I would like some ideas on where to place the main line coming out of the bottle. I haven't decided where to mount the 10 lb bottle yet, either, just somewhere in the rear like the spare tire area or remove the cd changer and place a 5lb (which i haven't bought yet) bottle there or just place it where the t-tops mount...
Keep the line under the car and out in the weather or snake it through interior? Pics??
Thanks ahead of time,
Brad
Brad
after you do it once it will take you 10-15 mins, 3 screws, and side panel comes off, torq bit for the seat belt, and 2 10mm bolts to slide the computer out of the way. Start from the front push it through the gromet, grab it pull it through and push it through the panel the speakers in grab it from teh spare area then tuck it and go backwards
My bottle is mounted on the tunnel between where the back seats use to be. The feed line goes through the grommet in the floor under the car but above the Kenny Brown sub-frame connectors. The car doesn't see bad weather and is just a summer toy, so I feel pretty safe that it will last a while.
