!!!CME, True Dual, X-PIPE, 3 Inch, CatBack Exhaust!!!
Has Anyone in the total history of the 1998-2002 F-Body ever custom fabricated a x-pipe & tailpipe setup all three inch? I can't stand the noise through the TSP True Duals. So i want to use the 3 inch TSP x-pipe, 3 inch custom bends, and piece together a full 3 inch catback full stainless with the exception of the BMR panhard relocation setup, and SLP shotgun resonators for the raspy death by stainless slp exhaust sound anyone who has attempted or completed this task please chime in i hate y-pipes and single catbacks i want true dual musclecar exhaust
A true dual catback??? I think I know what you're looking for but I don't think it would be considered a catback. I've seen lots of dual setups exit out the back so I don't see why the CME would pose a problem with the right exhaust guy.
Kleeborp the Moderator™
I had to neck mine down to 2.5" after the x-pipe to get both pipes to go over the passenger side with no clearance issues...it also tucks up over my drive shaft loop with no problems. If you are hung up on 3" all the way, you'll most likely need to run one pipe over each side of the axle, and I don't like that routing since it gets really close to some electrical connections as well as the fuel feed line.
the guys at the local shop said they have mandrel bent 3 inch systems assembled there all the time for a small price of 8 different bend radius's and it would be like a slp stainless setup like a mustang would have and sound twice as deadly as the junkstangs plus altimate flow
over each sides of the axle is what i am trying to customize with 2 slp resonators and a jegs, stainless works, or some othe muscle car you fit it true duals kit very soon
And I've said it previously, but if you run a pipe over the driver's side of the axle, you'll be coming VERY close to fuel lines, brake lines, and electrical connections that don't like heat. That is why GM didn't run the exhaust over that side of the axle.
good **** gentlemen, but i really want the true dual exhaust, sound, performance, look, like no other i will eventually have that raspy **** on ford lsp sound! A f-body would sound so badass with a true dual x-pipe with slp wide open responators and 3 inch stainless tailpipe setup. but if it works out i'm sure i could get the produced for a small cost if anyone would be enterested?
LSWNDR - I think i know the sound you looking for. The closest ive come without duals is what is in my sig, ill post some new better audio clips when i get a chance. For some reason its one of the best sound LS1 LM1 CME set-up's i have ever heard. But go for the 3" im sure ill eventually go that route when my mods demand it.
this is the closest i have come based off what you said you were looking for:
set-up: Ebay XS-S.S. LT's into TSP TD's with dual SLP LM1 resonators before the rear axle. no dumps, no turn downs...
i dont care to ever run the system all the way out the back. the way it sounds now is just SICK!!!...
LS1Tech Sponsor
We do them quite often here is a link of one of the cars that we've done! 3'' all the way back!
https://ls1tech.com/forums/showthrea...&highlight=paf
