LT1 internals???
LT1 internals???
what is the difference between the LT1 crank and the crank of any other one piece rear main 350? also is there more limitations to stroking on an LT1. id like to try and pull 427 cubes out of mine. is that possible?? am also planning on going to the GM847 cam. any ideas?
thanks in advance
karl
thanks in advance
karl
right about the crank, it is a plain-jane late model small block crank. you will not get 427 cubes from a LT1. nowhere near enough material in the block to cover the bore or stroke of a small block that size. cam is too low as well
Build is destined for failure since you are focused on maximm cubes and a mediocre off the shelf cam and never even thought to mention heads. In otherwords you are focusing on everything but the one thing that matters most. If you follow through bet someone with a 355 teaches you a hard leason about what you should have done different.
well perhaps you should have asked about my current mods, and even more so about my current heads. seeing as my heads were hand build by MTI and are stage 2 valves with stage 3 porting, im pretty sure they will hold up just fine. but thank you for your negative concerns. and if you have that 355, then by all means, lets dance....
stage 1 stage 2 stage 3 stage 4 stage 5 stage 6
ive always hated the term "stage" blablabla.
it makes absolutely no sense.
stage 1 ***
stage 2 face
sage 3 ****.
no details just illiterate lingo.
what is stage 3 porting and what are stage 2 valves?i guess im lost ...
stage 1 ***
stage 2 face
sage 3 ****.
