Wiring Harness
Wiring Harness
I just got this car--and me and my wife are in a tight situation financially, so my money is limited but having a running car is essential for me to be able to get to work.
I've known the car has a short, or multiple shorts, but this morning after the car had sat up for a full day without being driven got in and the car won't start loud click was all I got. The lights were still on and the short was still buzzing, but it wasn't thinking about turning over.
Not sure what I need to do here--don't know if I need to try and replace the whole harness (if you can just replace an accessory harness or something.) Any advice you guys could give me would be awesome because right now I'm a little stressed about it all.
It would be a good idea to review the wiring schematics and other information found at:
http://shbox.com/1/4th_gen_tech1.html
Shoebox lives in L.R. and would make a good choice for a Nobel Prize in LT1 Technology. If he can't walk you through it, it can't be fixed.
Good luck.
Good luck.
Well we got in there and looked at it.. it was the RAP Circuit Module.. it was hummin and hot. There is a Red Battwery Wire going to it that is constant hot. I don't have electric options on my Car, so I have never seen this before, I thougt it was an Alarm Module or something.
Hopefully all that has to be done is to get a new one.
The Horn doesn't work, that's a different story though..it's got power on the wire out of the Relay, but not at the connector at the Horn..probably a short somethere..
No.. it's factory connections. I think something in the Module shorted out, and it was draining power.
As far as the Horn, there is a break in the wire somewhere. The Fans are spliced into a couple of Fuses as well..they are made to constant run. When we get a day off that is on the same day, I'm goin to help him re-wire those to what they should be.
It's not too bad.. just little stuff.
