EFI V5 Live users........ Help
Re: EFI V5 Live users........ Help
You have to go to the PID tab and scroll down a little bit and select PID for "Misfire Cyl 1" to 8 you will need 8 free pids in order to do this. I dont know if you need to enable other pids to get those to log but that wil get you started.
It turned out to be im running on 2 cyl only. The gap on the spark plugs were 0.035 and that caused the whole problem. I swapped it with other plugs and gapped them at 0.052 and it worked just fine. No misfire anymore.
