Suspension & Brakes - Where can I find bump stops
CAMJAG
08-04-2008, 02:46 PM
Besides the dealer, looking for 17" rim bump stops. Where can I find them? Or if anyone has a set laying around
Choppers
08-04-2008, 02:55 PM
i got mine from gm parts direct
hpjunky98
08-05-2008, 03:10 AM
The Z28 bump stops are actually alot better. They aren't as harsh when they hit the axle tube, which helps both ride and handling. Bumpstops are part of the working suspension and they acually act to effectively increase springrate when in contact. If you have the 17" rim bumpstops, you are actually using an inferior part. This is one case where GM gave the lower models the better parts.
Im sure any dealership or GM parts direct or SDPC would have them.
CAMJAG
08-05-2008, 10:12 AM
I have 18' ZO6 wheels on my car now and I was told that I would need to upgrage to the 17' bump stop. For one I just bought this car and the bumps stops are gone off the car so I need a set either way.
If it even matters should I get the 16' bump stops and the SLP spacers? Or dont even bother with the spacers
CAMJAG
08-05-2008, 10:35 AM
What is the part #?
sixvi6-camaro
08-05-2008, 07:38 PM
all the SS/17" bump stops do is limit your suspension travel a lot to keep the tire from catching the wheel well lip. Personally I'd get the Z28 bump stops and roll the inner lip on the 1/4" panel wheel openings.
Mr. Camaro
08-05-2008, 09:34 PM
Just go to your local chevy dealership and get them, they're pretty expensive though. I think I paid $30 or $40 something each.
CAMJAG
08-05-2008, 10:14 PM
I know thats why I want to try and find them some where else :bang:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
