10.44@131 Finally got a Clean pass. Remote Mount 76MM S-10
Old 08-05-2008, 11:10 AM
Black X's Avatar
Default 10.44@131 Finally got a Clean pass. Remote Mount 76MM S-10
After a few track outtings struggling with 60 foot times and then having my meth kit fail 2 weeks ago I finally got a good clean pass last Friday.
I was a little nervous about the Meth kit working so I only ran at 10psi creeping to 11in the top of third.
Two-step at 2800 on the foot brake only roughly 2psi at launch. Good clean sixty foot of a 1.54
here is the slip.
Unfortunatly buddy dropped the video camera and was unable to recover the pass off the hard drive.
Combo:
370 Cube Iron Block
Compstar rods
Diamond 15cc dish
Trend H-13 Pins
Cometic Gaskets
Patriot StageII LS6 heads
Tony Mamo ported 90/90
Remote mounted PT76GTS
Snow Performance Meth kit
Finishline LVL5 4L60E with billet output
Yank SS3600
Currie 9" with 3.73
MT 275/60/15 DR's
Raceweight 3988LBS with me.
Couple pics of the truck
I had full intentions of stepping to 14psi and going a little harder but oil downs were the topic of the night and I only got one pass.
Old 08-05-2008, 11:12 AM
LS1Tech Sponsor
hellbents10's Avatar
Nice job, good run.
Also is that a passenger? do they let you run 10's with a passenger in Canada lol?
Old 08-05-2008, 11:17 AM
dlove's Avatar
badass
Old 08-05-2008, 11:28 AM
Black X's Avatar
Originally Posted by hellbents10
Nice job, good run.
NO I should have mentioned. The pics shown are from a 100' shootout event. being only 100' passengers are allowed and helmets are optional. Our track is IHRA sanctioned and all rules apply.
Old 08-05-2008, 12:40 PM
LilJayV10's Avatar
Sweet times man! That truck is heavy!
Old 08-05-2008, 01:29 PM
Black X's Avatar
Race weight is same as street weight. Still had spare, 2-10" subs and 2 amps behind the seats. Cruise control and aircondiditoning. No real effort made to save any weight.
Old 08-05-2008, 07:09 PM
Navy David SS's Avatar
Nice run. You need to post your times in the "Turbo List" above so you can be added
David
Old 08-06-2008, 11:59 PM
NYSS Guy's Avatar
Your setup looks really similar to mine...just the vehicle looks a little different! What compression ratio are you running?
Old 08-07-2008, 12:27 AM
daniel6718's Avatar
blackx hows that truck 3988? i thought a stock s10 was about 3000...extended cab like 3150...v8 id think would addd about 200 for the whole pullout?
Old 08-07-2008, 01:13 AM
Black X's Avatar
trust me it is. But just to humor you
i will start with your baseline of 3350 for a V8 S-10
Add-50lbs currie 9"
add-150lbs Cage
add-70lbs subs and stereo equipment
add-50lbs for spray in box liner
add-50lbs remote mount turbo setup
Add-230lbs driver
And that puts you at 3950LBS it adds up quick.
Old 08-07-2008, 01:15 AM
Black X's Avatar
wow they are similar arent they. Mine is 9.5:1 static compression.
Old 08-07-2008, 01:47 AM
bottlefed98's Avatar
congrats, ive been watching this truck get quicker and quicker over time on S10forum.. glad to see youve stuck with it and got it running like it is
Old 08-07-2008, 07:15 AM
Websy21's Avatar
Very nice, only can imagine how faster it would be with some weight savings close to stock
Old 08-07-2008, 08:19 AM
Black X's Avatar
Thank you bro... Sure has been through some changes. This is the 4th Motor in only 4 years LOL
Old 08-07-2008, 08:20 AM
Black X's Avatar
Thanks, I think this winter I will spend a little time looking at where I can save weight without giving up Items that I enjoy having on road trips.
Old 08-07-2008, 09:37 AM
LS1Tech Sponsor
My v-6 regular cab with roll up window and manual lock was 3379 with me in it. Add the extreme stuff and the stereo, I can defiantly see that.
Old 08-10-2008, 09:06 PM
bigd98's Avatar
goob work! vary nice times!!
Old 08-10-2008, 09:43 PM
Black X's Avatar
Little Update
Went 10.42@132.25 on Friday 1.51 sixty foot.
Tryed to up the boost to 15 but the fuel pump wont support it. I guess its time to upgrade the fuel system
Old 08-10-2008, 10:20 PM
Websy21's Avatar
Originally Posted by Black X
Little Update
Are you running a single 255? Time for dual walbro's, its the easiest route anyhow. I bought a custom tank, external, etc, etc and said if I did it again it would be the dual intank's. Good to 1000rwhp and cheap
I wanna see what that lil beast can do once you get the wick turned up!
Old 08-11-2008, 08:23 AM
Black X's Avatar
Yeah Single 255 with a kenne bell BAP. Going to have to upgrade to somthing.
Quick Reply: 10.44@131 Finally got a Clean pass. Remote Mount 76MM S-10
