What kind of vaccuum are you guys pulling(tial bov spring?)
Old 08-05-2008, 05:57 PM
Crowder's Avatar
Default What kind of vaccuum are you guys pulling(tial bov spring?)
Just wondering how much vacuum you all are pulling or think i would. I honestly dont have the slightest clue. my setup is in sig. thanks Chris.
Old 08-05-2008, 06:04 PM
Black X's Avatar
IM gonna guess you would be in the 8-10Inches range with a 5.3 and a cam like that. your prolly gonna want the 7lbs BOV spring.
Old 08-05-2008, 07:52 PM
Crowder's Avatar
thanks
Old 08-05-2008, 09:49 PM
SPRAYED 01's Avatar
Mine is at 14-15 at idle. I had the 11lb spring and it would not open unless i was at full boost and then let off. I put the 7lb spring in and it works perfectly.
Old 08-05-2008, 10:04 PM
9 Second Club NA
Dragaholic's Avatar
It seems every where I read about the Tial, the 7 lb. spring is the most used. That's the only one I ever hear about.
Old 08-06-2008, 11:09 AM
Crowder's Avatar
cool, thanks guys
Old 08-10-2008, 04:01 PM
fenix999's Avatar
mine is pretty close to 20 vac at idle. good luck figuring everything out man
Quick Reply: What kind of vaccuum are you guys pulling(tial bov spring?)
