Cam Install
Old 08-28-2003, 02:12 PM
KmartZ's Avatar
Default Cam Install
224/224 .581/.581 will I be able to use the stock pushrod length?
What should I get the 7.40 or 7.35?
Old 08-28-2003, 03:53 PM
jmX
jmX's Avatar
Default Re: Cam Install
With only the information you've given we can't say, but if you are using stock unmodified heads then 7.400 without a doubt. 7.350 with that cam and stock heads could be really bad.
Old 08-28-2003, 04:23 PM
1999_SS_M6's Avatar
You wouldn't modify your pushrod length for the sake of any cam. You only modify your pushrod length if you alter your valvetrain geometry. By that, I mean mill the heads, or go to a different rocker setup that's incompatible with the stock setup, etc.
Old 08-28-2003, 07:47 PM
KmartZ's Avatar
Lift: .581/.581 Dur@.050: 224/224 LSA: 112 114
OVATE WIRE SPRING SET, USE WITH STOCK RETAINERS
That's what I have so far. The brand is Comp Cams.
I think I will go with the CHROME MOLY PUSHRODS 7.400' (STOCK LENGTH)
I am getting this stuff from Speed Inc.
