High RPM Miss
Old 08-06-2008, 09:44 AM
sw07gt's Avatar
Default High RPM Miss
I know theres a new one of these threads like every hour but it seems like every thread someone has a different answer for the same problem. My original problem was a hesitation around 5k. This morning I was late to work and low on gas so I didn't stop. Anyways the car didn't have enough gas to start so I had a coworker take me to the gas station. Got a gas can etc. After I put a gallon in then went and filled up I noticed that now when I hit it the car just completely cuts out at 5k. Someone please help I want the car ready to autocross by Sunday and I've missed the last 3 because of this damn car.
Old 08-06-2008, 09:39 PM
ElkySS's Avatar
sounds like a fuel pump to me. that was my problem. hook up a fuel pressure tester
Old 08-06-2008, 09:51 PM
Fixxer99TA's Avatar
Check your fuel pressure at the rail as stated above.
Sounds like that fuel pump was getting weak, and then running it dry finally was the last straw. Running a fuel pump dry even if its newer is never a good idea.
Old 08-08-2008, 01:55 PM
bufmatmuslepants's Avatar
could always be a clogged cat...
Old 08-09-2008, 11:16 AM
sw07gt's Avatar
Well it stopped cutting out and then I totaled the car so that sucked.
Old 08-09-2008, 01:34 PM
Fixxer99TA's Avatar
Damn dude, what happened? Your ok I take it?
Old 08-09-2008, 01:39 PM
wsick's Avatar
yeah sounds like the fuel pump is out, like stated a few posts up its never good to let your car run dry
Old 08-09-2008, 05:26 PM
sw07gt's Avatar
Yea I'm fine. I rolled it on a 1.5 lane road in the dark that I wasn't familiar with.
Quick Reply: High RPM Miss
