dash gauges hookup in non f-body ?
Old 08-06-2008, 04:48 PM
jeejee's Avatar
Default dash gauges hookup in non f-body ?
Where could i find a schematic of the dash hookup from an f-body ?
I'm planning on installing one in a non ls1 car.
Can the wires coming out of the gauges at the back be hooked up straight to the sensors and lightswitches ?
Is there no computer needed to let the dash work ?
thanks, Jeejee
Old 08-07-2008, 01:06 PM
jeejee's Avatar
Ttt :-)
Old 08-08-2008, 11:15 AM
TPI TERROR's Avatar
Default dash
I believe you can use a 93-97 (LT1 style) dash for a non-LS1 car. 98-02 Dash clusters use serial data from the ECM.
Check this out http://www.thirdgen.org/techboard/in...ring-good.html
Old 08-08-2008, 05:10 PM
jeejee's Avatar
could i not just hook up this "serial" wire to the engine ecu ? (is the engine ecu the ecm you are referring to ?)
Old 08-13-2008, 03:15 PM
jeejee's Avatar
anybody else can shed some light on my last question ?
Quick Reply: dash gauges hookup in non f-body ?
