stock compression w/ a turbo?
Old 08-06-2008, 07:37 PM
leonpiper69's Avatar
Default stock compression w/ a turbo?
im starting to buy my parts for my ls swap into a fox body and after loking at my options for headers, i have considered doing manifolds with a turbo.
but my question is do i need to do anyhting to my motor?
it has stock pistons and i guess thats like 10:1? (its an 01 ls1) and i know any forced induction motor likes arounf 8.5:1.
Old 08-06-2008, 08:55 PM
NemeSS's Avatar
u will still be able to have around 5-7psi with 60 lb. injectors and proper tune
10psi with race gas would be pushing it
u will need upgraded valvesprings and rod bolts for sure.
jerrad's Avatar
I believe the lq9/lq4 heads will drop the compression.
Old 08-06-2008, 09:14 PM
NemeSS's Avatar
317 6.0 heads will dropthe comp. ratio to about 9.5:1
with 6.0 mls head gaskets
Quick Reply: stock compression w/ a turbo?
