Driveshaft swap...
Driveshaft swap...
Ok... I'm a newbie. I just swapped from the OEM 1-piece steel to a 1-piece OEM aluminum from a '98+ car. After I installed the new aluminum DS I thought it looked like it was a little short going into the trans? It does go in enough and it seems to be working fine. I'm still a little concerned about the gap (from memory, it seems like a larger gap than on the steel one)... Is this normal?
I have a '99 V6 with a GU6/G80 rear.
See pic...
See pic...
