what size belt with underdrive pullies
hey guys i gotta 02 camaro ss with the asp crank pulley the small belt from the crank to the ac compressor broke today is this belt going to be smaller then the stock size now?
1 Post
Yes the belt is smaller than stock. If you can afford to wait, Order a goodyear gatorback the part # is GTR-4040377. Very good quality
If you just want to try to match up at a parts store the belt is 4-Rib, 37.75 in. Length
is that the big serpentine belt you are talking about? i probably should replace them both tho the small belt that goes from ac compressor to crank pulley is the one that snapped.when i had the work done i no 2 of the pullies where changed the asp crank pulley and im guessing the alternator.
