ttop sail panel part number?
Old 08-07-2008, 10:55 PM
ZMONSTER!'s Avatar
Default ttop sail panel part number?
What is the t-top sail panel part number? Need to get a replacement!
Old 08-08-2008, 06:43 AM
firebatbirdv8's Avatar
The part Number for the sail panel is 10254708, you will also need the two apliques one on side each side, part numbers for these are 10240164 for right and 10240165 for left (these are the small triangle pieces) hope this helps.
Old 08-08-2008, 09:12 AM
ZMONSTER!'s Avatar
Very much thank you!
where is the best place to pick these up? I looked at GM parts direct snd its nearly 400 bucks.
Old 08-11-2008, 05:25 AM
ZMONSTER!'s Avatar
Ok seriously where can I get one of these for a decent price?!
Old 08-11-2008, 06:24 AM
I got mine under warranty through a gm dealership here in the uk, if you search on the web you will find aftermarket company's that can supply you a sail pannel.
Old 08-11-2008, 06:30 AM
ZMONSTER!'s Avatar
ya gm parts direct so far is the best at 389. Im looking for less than that!
Old 08-11-2008, 11:17 AM
Brian2006's Avatar
I've seen some at junkyards for $120. However, it's not the easiest thing in the world to remove
Old 08-11-2008, 07:29 PM
Nauty99SS's Avatar
THOSE WILL COME OFF THE OLD PANAL WITH A LITTLE tlc WITH THE PUTTY KNIFE .. sorry for the caps ... darn kids .. i took mine off and painted them with the top
Quick Reply: ttop sail panel part number?
