Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Late Model Speed Magna Charger LS1 Fbody Supercharger Kit
Old 08-08-2008, 10:37 AM
rick@latemodelspeed's Avatar
Default Late Model Speed Magna Charger LS1 Fbody Supercharger Kit
Our install kit allows our exclusive, custom Magnuson supercharger kit to be installed in any 1998-2002 GM F-Body. The kit requires minimal cutting to the cowl area, and comes with a pre-cut metal panel to box in the cut area.The factory plastic cowl remains fully intact, and the kit requires no relocation of any factory items like windshield wipers, A/C components, or power brake booster. The kit comes complete with everything you will need to install, including templates, and fully detailed color instructions. Included in the kit are the following items:
• Complete, fully assembled Eaton 112 Supercharger system by Magnuson
• Cast aluminum intake manifold, with internal liquid to air intercooler
• Holley 90mm Throttle Body
• Complete fuel system upgrades including high flow injectors, and Racetronix high flow fuel pump kit
• Complete heat exchanger with coolant pump, and all necessary lines and fittings
• Step by step, easy to follow instruction manual, with color pictures
• Custom brackets, metal panel, and parts required to fit Supercharger to your chassis
• Custom programming of your vehicles ECM (you must send us your ECM)
• High flow air intake kit
Your Price: $6,495.00
Old 09-23-2013, 09:34 PM
9momba8's Avatar
ive been hearing that the magnachargers for 98-02 camaro is 50 state legal. is that true? and where can i buy/see more info about the kit?
Quick Reply: Late Model Speed Magna Charger LS1 Fbody Supercharger Kit
