ATI Superdamper gap between pieces
I just received my ATI Super Damper (917264) and the instructions aren't all that great in it. Anyway trying to put it together I got the hub into the accessory shell ok and that sits flush.
The A/C pulley center section sticks out .54" from the pulley and looks like this part is supposed to sit into the space between the hub and the accessory pulley.
When I try and put then together though there is a .12" gap between the two pulleys, is this normal? I have attached a couple images to illustrate the issue.
Thanks for your help.
