what to do? lq9 swap g-body
i picked up a lq9 for 300 for my 1985 monte carlo ss after i herd about the l92 heads. the motor is complete from intake to oil pan with all sensors. it has no accessories which is my first problem i plan on using brp mounts and headers. what accessories to use truck, camaro, or gto? what is the difference in harness and computer for a 4l80e? how to get the speedo to read and what tank/pump to use?
You might ask BRP which accessories will fit best with their mounts. They recommend a pan that sits below the crossmember. I wouldn't use it. Use an f-body pan and knotch the frame cross member. Be sure to box it back in so it will be plenty strong. I swapped my tach and speedo to Autometer units.
