APS TT C6, feels like its hitting fuel cut/falls flat on its face?
Just did an oil change and topped off fluids, and when I started the car back up again and drove it, it started hitting some some of a fuel cut or something right around 4-5k depending on conditions, gear etc. It happens faster the harder you get on the gas...... I saw a pending MAF voltage low code, and swapped in a new MAF, but that did not solve the problem. I then noticed the 30A fuse holder for the MSD BAP was bulging/melted. Thinking it might have gotten some water in it or something? Or perhaps a bad fuse? Anyways, I put a new holder and a new fuse in, and it still has the exact same problem. Even part throttle out of boost at about 4-5k it just falls completely flat on its face, like some sort of a fuel cut? I checked the BAP fuse again, and its still just fine. Any ideas? TIA! Mods: APS TT, Borla.
TT-TECH Veteran
Let me give you a big list, probably likely you have one already started lol! Change fuel filter, check boost levels have they changed?, and also check the TB closing under boost its happened to a lot of people and even checking your fuel trims on the stock O2's will tell you if you are lean or fat like with a tech 2. Not as accurate, but will give you an idea and checking the plugs could tell you a bunch on fuel also. Check your FP after the filter change and see if it ever dops etc... Stock pump can fail as well as an aftermarket one of any name brand check vacum hoses like to the FPR and make sure you atleast put a tie wrap around them to help hold them under boost etc... Good start for now GL!
Mine did that when i changed the throttle body and i open the blade all the way with the adjusting screw.then my TPS was not reading correctly and would shut my fuel off on the computer.check that see if that works.
dude this might be the stupidest post ever, but it sounds like your charge pipe is completely popped off somewhere and you might have overlooked the simplest thing... It revs softly and fine all the way up but as soon as you see .01psi of boost or anything like that the car feels sluggish and like you say, "falls on its face"... Happens alot more than one might think either way good luck but i say double check and tighten down all silicones and t-bolts/clamps
