going carbed, gauge question....
well since i am going carbed and not useing a normal wire harness, i have a question.
i have a full set of vdo gauges, they are all electronic. oil pressure, water temp, ect, ect.
my question is, can i use the factory oil pressure sender and water temp sender to run my gauges?
is there anything special i need to do to make this work?
well i know you can tap into the harness and run them on a injected car.
my questio is, what do i need to do to make the sensors read?
do they need a ground? any sort of power?
I have an LS2 Datsun with a full set of functioning guages. you just need to get creative plumbing the original sensors into the new motor.
The instructions for your VDO guages should answer all the questions you are asking.
