ported TB installed
Old 08-10-2008, 04:34 PM
SSJIMMY's Avatar
Default ported TB installed
I ordered a Ported TB by Jantzer through Chris at CC Performace great product and service and i got it in only a few days. I didnt opt for them to paint it or anythin and when i got it I decided i would paint it myself. took it a part scuffed it up and cleaned it and then sprayed 3 coats of a a night black metallic enamel a really cool color i think. It looks black on the cap but its more like a really dark gray kinda like the dark carbon color GM has on there trucks. I then sprayed 4 coats of clear and let it sit overnight.
So today i get home from church and start at it get the old TB off transfer the sensors over and went to put it on got the 3 bolts started. then started tightening the 2nd one and it just snapped in half. fun fun so my Dad and I play with it a bit to see if we could back it out tried all our plyers and wrenches nothing could get ahold of it. so we got out the dremel and cut a groove in it and able to get it out that way very lucky we didnt have to do more.
So went and got some mroe bolts and a 2ft 5/16 fuel line hose to bypass the coolant going into the TB got everything bolted back on and it does seem to run better and have better response when i hit the gas ill take it to the track in a week or two and see if its enough to drop me that .11 to get into the 12s.
well here is some pictures enjoy.
Installed on the car
Old 08-10-2008, 04:37 PM
shdybrady1988's Avatar
i liked the idea about painting it. I havent thought about. Looks good. Did you do the knife edge and bump stop mod as well?
Old 08-10-2008, 04:42 PM
SSJIMMY's Avatar
it was ported by Jantzer but he did the bumpstop but dont think he does the knife edge not sure though.
Old 08-10-2008, 04:50 PM
Tech Resident
ChocoTaco369's Avatar
What was your method for painting it? Painter's tape? I'd like to see how you did it because it turned out nice.
Old 08-10-2008, 05:29 PM
SSJIMMY's Avatar
I took the blade and shaft off then scufed it up and cleaned it off then used the blue painters tape to tape it off then sprayed 3 coats of color 4 coats of clear and let it sit for almost 24 hours.
Old 08-10-2008, 05:41 PM
firefighting1101's Avatar
very nice. Chris at cc performance is a good guy, and im glad to see he is selling the jantzer throttle bodies they really are a very nice piece
Old 08-10-2008, 06:09 PM
Tech Resident
Cool. Did it require any special tools to get the blade and shaft off, like hex tools or something?
Old 08-10-2008, 07:30 PM
SSJIMMY's Avatar
you will need a set of torx srewdrivers to take the blade and shaft out as well as the sensors.other then that nothing special 10mm socket and screwdrivers.
Old 08-15-2008, 09:09 AM
SSJIMMY's Avatar
here are some pictures of the bypass hose i did its a 5/16 fuel line hose 2 feet long. the radiator side is a tight fit but so far it seems to be working just fine no problems at all it is the small hose in the middle.
Old 08-15-2008, 10:43 AM
Raise's Avatar
Only other thing id do is polish up your sensor housing on the top right of the tb. they really do clean up nice.
