Just dynoed my TT ZO6
Old 08-11-2008, 07:48 AM
venom ws7's Avatar
Question Just dynoed my TT ZO6
I just bought this car last week so I took to the dyno to see how much power this thing have I still waiting for the builder of the car to arrive so I can have all the info on the car.
01 ZO6 with less 30k miles
Mods that I know:
Engine:
Build 346ci 8:5.1 compresstion, MTI Stg 2 heads, custom turbo cam, all valvetrain.
stock trans and rear.
STS TT ZO6 dont know the size but the owner said they are the biggest turbos STS offer.
Fule system
with 9psi and Air/Fule ratio 10.0 all the way to 6000rpm and 13.0 after 6000rpm to 6400rpm (thats whan I let go)
The car made 499rwhp 476rwtq SAE with hot wheather.
We tried to tune the car but the tune was locked
What do you guys think about the numbers Oh I also found all stock Cats and stock H-pipe are stil on the car????
I will remove the CATS and add 3 X-pipe (stock headers) and retune with 13psi
Any comments will help
Old 08-11-2008, 08:03 AM
Dumb Ass Vette Moderator
ls1290's Avatar
First thing, the tune is McFucked. The A/F ratio is way off on both ends. Best thing to do is get a new PCM and start off fresh. Once you get the car tuned, it should make a bit more power.
Keith
Old 08-11-2008, 08:04 AM
1INSANEGTO's Avatar
Those numbers don't match your sig by any means
Old 08-11-2008, 08:05 AM
ls1290's Avatar
Secondly any tuner that locks a PCM should be whipped with a Corvette hood performance seal until they admit their wrong doing
Keith
Old 08-11-2008, 08:13 AM
OUTLAWZ RACING's Avatar
Once you open the exhaust up and tune you should be around 500+ on 9 psi hows the fuel system set up that may hinder you.
Old 08-11-2008, 08:15 AM
venom ws7's Avatar
I have the dynp graph of 705rwhp from the last owner with 13psi pump gas mixed with 109octane
I just want to retune the car since its been down for over 4 months.
Thnak for the replies guys.
Old 08-11-2008, 08:19 AM
fotoboy's Avatar
I would def check into your fuel system and make sure it is up to it. Def need to get it tuned. I also dont think your going to get 3 psi from removing the x pipe and cats either.
Old 08-11-2008, 08:22 AM
venom ws7's Avatar
I didnt say I will get 3psi from those mods I said I will add more 3psi
Thanks.
Old 08-11-2008, 09:09 AM
50_Dave's Avatar
Did the dyno have load on it?
On an unloaded dyno, my car only makes 6 psi at 4k rpm, but it makes 14 psi by 3800 rpm on the street. This will effect your dyno numbers.
Old 08-11-2008, 10:19 AM
ayousef's Avatar
Bro the A/F is not even at 10:1 beleive me thats the lowest than your wideband can read its probably below that which is REALLY BAD, dont drive the car like that, fix the damn a/f 11.5 sounds good.
Ps. it doesnt look like a load dyno (from the looks, I might be wrong). I say fix the tune youll get a lot, if the a/f is messed up that much, im pretty much sure the entire tune is trash.
Old 08-11-2008, 12:16 PM
ArklaTexan's Avatar
Those are down right pathetic numbers for a twin turbo LSX car period! get a new pcm and have it tune and 600rwhp (with fuel system of course) should easily be attainable.
Old 08-11-2008, 12:52 PM
Shorty Director
VINCE's Avatar
I think the previous tuner tuned the car at a higher boost level and off the wastegate the car is really fat for safety reasons. It might be down on power, but the alternative could be a blown motor.
Get off the numbers tip and wait for the guy who sold you the car. He should have access to the PCM and he will tell you whats going on. Yes you have paid for the car, but to protect themselves from the buyer coming back and saying the car is messed up they could have temporarily locked the pcm. Hell you are already beating on the car and making negative post. I would wait till you get more answers from the seller.
Having a NON blown up motor is a good thing.
Old 08-11-2008, 03:20 PM
TNTramair's Avatar
why does he need to get a new PCM, cant he just have a GM dealer reflash it back to stock??? or are vette's differant. when my pcm was locked a long time ago by a sponsor all i did was took it to the dealer and they flashed it back to stock....did the trick...cost me $90 but cheaper than a pcm.
Old 08-11-2008, 08:33 PM
Qwick98Z's Avatar
All you have to do is reflash the PCM with the stock program, then retune the car.
See if you tuner has a TECH 2, get the VIN and go to the dealership, sometimes they will load the program into the TECH 2 for free.
Old 08-11-2008, 11:11 PM
TT-TECH Veteran
Inspector12's Avatar
Flashing the PCM back to stock doesn't always work when they have been locked for the guys that suggested that and he will loose his injector tables etc... If he is not a qualified tuner etc... I day get a little tunning help either from the previous owner and tuner etc... GL nice car none the less.
Old 08-12-2008, 06:26 AM
venom ws7's Avatar
Thanks for the replies guys I will let you know what happens ASAP.
Old 08-12-2008, 07:19 AM
RsSean's Avatar
Kinda low IMO. I would think at 9psi would should be making more that 500 at the wheel.
Like LS1290 said the A/F is off.
